are all piston manuf. base there numbers on a 9.000 deck height? I was looking at srp/je pistons and thats all I saw for a sbc. The shp blockcomes with 9.025. I thought they would have to be checked but do they have to be machined brand new? I dont want to wait untill monday to ask my machine shop. They are out of town. Thanks guys.
It depends on the CH etc
Stroke/2 = X + rod length + compression height = deck location height @ piston
For example,
3.48" stroke/2 = 1.74" + 6" rod + 1.26" compression height = 9" deck
This means for the piston to be flat with the deck, the deck height needs to be 9"
Now I will give you my opinion, If your using an off the shelf piston I would like to see the piston @ least .005" out of the hole. On 400 GM blocks I like to see .010"+ as I have seen better ring seal and IMO its because the 1/16" ring clearance is .0018" to .002" as this allows gas pressure to apply the ring and with the piston out of the hole its a little easier to get has pressure heading down that way than say if the piston was .025" in the hole
Just my opinion and what works for me
