1 - 5 of 5 Posts
I have a non return style fuel system on my car and have no way to install a return line. I was looking but have not found a non bypass regulator with boost reference port, any one know of a company that makes a 3.5-4psi dead head regulator that is boost referenced?
my pump is a internal bypass so does not need nor can it be setup with a return line. the reg might be but had problems running this style pump that way as it needs the pressure to steady flow.
I ran one with a blowthru carb, been a while, but thought I used an Aeromotive reg. One thing I
noticed at times was I would get a spike when the pump was first turned on, then it went normal.
1 - 5 of 5 Posts
