1 - 4 of 4 Posts
Not data loggers.
I was wondering how much info you track at a meet. I understand that meterology is tracked by a lot, but what all do you track? I am trying to build a comprehensive spreadsheet that will prompt for info.
Drunk and Disorderly
Densety altitude, humidity, dew point, temp, wind direction and speed, Pyro temps, A/F ratio, coolent and oil temps (max and staging) and of course 60 ft, 330 ect., ect.
I ajust my tire pressure based on my 60 ft. If 60 ft is down, I am probably spinning, and drop air pressure. I have found that about 8 psi going into the water box hooks for me in most conditions. The only time this has not worked for me is at a temporary track (airport runway) and good track prep was impossable. I ran 10 lbs and added weight to the back of the car.
1 - 4 of 4 Posts
