I have searched high and low to fine someone that can tell me which solid roller lifter i need to run on this dart sportsman 351 block ' running brodix 201 heads...Im using a standard solid roller comp cams cam...The lifters i have right now are the 87879-16 and everything looks like itwould work fine ' except the predrilled oiling hole is running long ways ' the same way as the oiling galley......I pulled 1 of the galley plugs back of the block & im showing 100 thous's of the cutout ' which they say is fine' but the predrilled oiling hole was facing longways and was dead center of the oiling galley....Just talked with crower & they say part # 66378 will work ' but i pulled up a pic on jegs and the lifter looks shorter but not sure...Hes suppose 2 send me more info....I know as many dart sportsman blocks that are out there running brodix 201 heads someone has 2 know of a lifter that will work...They will have to be ex lifter centered & intake 180 offset like these comp lifters....thanks...
Anyone know if these lifters i have will work ok???
I already tapped the hole in the back of the block' and installed a 1/8 inch pipe plug....I have 1 plug drilled 90 thou's ' talked to dart yesterday & they said they would start with 140 thou's ....At least i will only have to remove the intake to change the restrictor if i need to when the engine is done.....thanks..
