1 - 10 of 10 Posts
whats the max bore you can take a dart iron eagle small block? thanks
SBC
4.200" recommended
4.250" has been done many times
Discussion Starter · #4 ·
i have a buddy who has one for 1000 bucks thats at 4.195 right now, and he seems to think it needs a sleeve in number 6 hole, i havent looked at it yet, but i have a cola 4 in crank and sb2 heads.....and know this would be better then the 509 blocks i have now.....thanks for the info
Hard to say on the sleeve without seeing it. If thats the case, sleeving down a bit will help keep the deck to head bolt interface happy.
how much is the small base circle cam going to hurt the engine or engine life?
Although the blind headbolt hole should provide some resistance to cracking, installing a sleeve into a block with a 4.200 bore means the sleeve OD is at least 4.300. I would think at that point you would be within a few thousandths of the threads. Not a good investment IMHO.
The SB2 will have a lot on the rocker side, the smaller base will not be the best, but plenty run well.
Discussion Starter · #10 ·
im not 100 percent sure about the sleeve, and why couldnt i sleeve it back down to a 4.125 bore? whats the goin price for these blocks, raised cam and spread rail?
1 - 10 of 10 Posts
