Anyone ran into different bolt spacing issues between the front bolt bosses from side to side? I was planning on moving my crank trigger from the pass side to the drivers to install a low mount alt on the pass side. The alt bracket kit is reversible from side to side so I thought this was an easy switch. The spacing on the passenger side is about 1/8 inch narrower. Neither bracket will work on the opposite side.
On a factory BBC these are the same, I call Dart and they said they should be the same 'but they have heard of this issue before and the their prints show them the same, sorry cannot help you'.
They are clearly not the same.
