1 - 9 of 9 Posts
any one have this issue with the big chief heads oil return holes not lining up with there dart big m block. if so what did you do to fix the issue. I have maybe a 1/4 of the hole lining up. Thank You
Installing drain back lines will help. #8 size from ends of heads to side of oil pan inline with main caps. And yes, grind away.
that's why you need to mock up all the parts before assembly to check for that stuff,a die grinder works
Discussion Starter #7
I have the same issue with drawback holes on my 12* Profilers....So I have -8 drainback lines on both heads straight to the oil pan
So did you just add the lines or did you also grind to get original holes to match up etc.
I cleaned up the casting flash, but that was it. They are also partially blocked by the head gaskets too.
1 - 9 of 9 Posts
