1 - 20 of 41 Posts
I got a fresh 555 dart big m going and noticed oil pressure is lower than expected
I have valve spring oilers and remote oil filter with bar/plate style b&m cooler
Engine is in a 3rd gen camaro, so we have filter adapter in the block that has 1/2 npt to -10 outlet running 4 ft of -10 line to cooler mounted at radiator in front of car then 1 ft of line to remote filter housing behind driver headlights basically, thru filter then back to motor thru another 4 ft of -10.
Also from remote filter i have a -6 line takeoff to feed a distribution block near firewall, 4ft away from filter. Distribution block has my oil pressure sender for stock camaro oil gauge and a -4 takeoff to feed the valvespring oilers in the covers.
Two oil pressure sensors. One in the back bellhousing area. One in distribution block off the remote filter housing. Both read about the same
Engine has .0025 rods and .0029 main clearance. It has bushed lifter bores with howards/morel solid roller lifters and it does not appear to drop below or above oil band hole in the bore. Not sure of the exact lifter bore clearance however but they were sized
Melling 10774 std pressure std volume pump
Had lucas 30w break in oil and then moved to 15w40 rotella to see if it changed pressure. It did help hot idle but wot was same
Its idled in the mid 30’s to near 40 cold (80 deg ambient) and hot idled in the 20’s psi at 1000-1100 rpm. At wot up to 6500 its only seeing 43 psi but flat and stable and gets to that pressure immediately on the hit.
It almost seems like i have alot of line and bleed off from the oilers which would drop prssure and the pump is on the bypass spring. Do i just need to swap out to high pressure spring?
You put a lot of added demand on the oil pump with the remote accessories and oilers. Need to upgrade the pump.
Just a quick test. I capped the -4 spring oiler feed and see 60+ at cold start idle. Stopped engine, hooked oilers back up and see 40 psi. Huge difference
TD 3550
Curious, why the complexity on the oil system. I'm seeing 9 Ft of -10. that's a bunch. plus the cooler/filter. Bunch of oil that's not in the motor. This a street rod?. Only guys i know that run oilers are at 800 CI plus. Better pump is an understatement. More lines the more chances of leaks. Too close for comfort at that oil pressure for me. My 598 and 632 run at 60 idle and 70 on the pedal. but with a Moroso billet pump. Be safe there..
Discussion Starter #11 (Edited)
Yeah street car. And is going to be turbo’d just breaking it in all motor right now. Figured a valve spring oiler would help keep springs and rockers well lubed at idle and cool on long drives. More life out the parts
Oil cooler for heat load and it has to be mounted up front because no where else to put it. Thats 4 ft away either way. Ran same setup for few yrs on my turbo sbc no issue. Remote filter since the headers are in the way.
I just tested the engine semi warm, 160’s coolant temp, without the oilers and its 50 psi idle and quick rev to 3500-4000 i see 65 psi so it may be good now at higher rpm. My buddy ran drag week with a solid roller 1100 lb open springs just fine without oilers so likely wontneed them anyway. Just thought it was a good idea. I dont have near that spring pressure.
Only issue now is if i plumb the turbo feeds off the system it may drop pressure again so may need a high pressure spring anyway
Did you use the cam bearings with 3 holes that is a huge bleed off if you prime the engine with out the intake on you would see what I am talking about.
Valve spring oilers eat up some volume of oil and its best to compensate with a pump that puts out more volume as you figured out.
Discussion Starter #13
Not sure, sheet says gmp-12LT cam bearings. Pics of them online show 1 hole?
Either way i’m seeing atleast 65 psi now on small revs vs 43 at full song without the oilers connected. So they def bled off more oil than anything else in the system. I’ll see what it does at rpm but i still may put in a high pressure spring
Valve spring oilers are usually another 3-4 GPM.... there's your 20 psi. If i had a dollar for every "I have low oil pressure" tech call I get after someone adds accessory oiling I wouldn't have to work anymore. People don't realize how big of a leak valve spring oilers and piston squirters add.
Discussion Starter #16
Yeah first i heard of it but makes sense. Dont know anyone running oilers personally. The pin holes in the oilers didnt seem to me that they would flow that much. Wish i had known better ahead of time and bought the higher volume pump and higher pressure spring. For now i will run without and maybe replace things after i get the turbo stuff done later this year
Discussion Starter #18
Put restrictor jets in for the spring oilers, they are never a bad thing for what you're doing...
And the 10774 should have came with the high psi spring in it already.
Said standard pressure and two extra springs were included but they are plain and look identical. Mellings description says low pressure spring included so maybe it is a higher pressure spring in it? My understanding is plain is 52 psi, pink is 70 and there may be a blue spring thats 60? I ordered some 70 just in case but sounds like i’d be better off with more volume of a 10778. I’ll try restricting the oilers first
Adding a higher pressure spring isn't going to accomplish anything if the pump isn't making bypass pressure now. There's too much loss in the system for the pump's volume. Increase the volume and the pressure will go up.
If you have 8 squirters @ .035" each, that's roughly the equivalent of having a .100" hole in your oiling system somewhere. That's a BIG leak.
1 - 20 of 41 Posts
