Just picked up a 2011 enclosed and thought I'd mention what I found today. It obviously came with the standard 4 D-rings in the corners. But they were attached with 1/4" flat phillips head, self piercing machine screws that were wound down through the plywood and into a metal backup plate.
No way I was trusting those screws so I went and got 3/8 grade 8 bolts, washers and nuts. Now the best part is when I went to remove the screws, all four of the ones in the left front ring were already snapped off even with the metal. It was obvious they had been broken by the torque of tightening them at the plant. Nothing was actually holding that anchor in place!
Just thought I'd mention it. Maybe take a look at yours if you have one of the less expensive trailers.
