1 - 4 of 4 Posts
I thought I would ask about this from a layman's perspective on how does one check or, know if there cam, timing events, and stroke are all working in sync to obtain maximum pressure per each cylinder?
I would gather this could be done by timing events and with a cylinder pressure gauge???
If someone can offer up there combo as an example, maybe this may help the mass's learn a thing or two and be able to find out there own engine info.
If this has already been discussed, my badd, got board:cool:
Feel free to delete this topic Mr. U.
Discussion Starter #2 (Edited)
Just to clear things up a bit, I am aware of how to find cyl. Pressure in each cyl., I just wanted to know (IF) the pressure we get from readings are the best with the selected cam and the adv./ret. adjustments. I know cyl. Psi is our friend and cams will be different.
You could model cylinder pressure and see how it changes with different cam events while varying rpm by writing a program in something like ees.
Or use pressure transducers.
Cranking compression is a lot different than at operating speed and a combustion process.
1 - 4 of 4 Posts
