And this is why you can’t get too greedy porting these heads! Lol
Nice, What kind of aluminum did you use? How did you prep it and stake it?I filled the crossover with aluminum… View attachment 439719
with a gasket?!?How the hell you keep a gasket between the ports? Might as well make a uni port.
I don't see a problem.How the hell you keep a gasket between the ports? Might as well make a uni port.
I was going with tool steel but got these Ti retainers for less and I spent most of a morning looking for a dual spring with no damper but couldn't find what I wanted. The Isky springs I wanted were out of stock everywhere. Already had the retainers so had to settle. Cam is <.600" hyd roller.Just curious, why not tool steel retainers or springs with no damper?
Nice cardboard back drop.Another of those "Drag and Drive" customers going with some ported Trickflow Twisted Wedge heads... Ported AFR intake manifold and new roller camshaft in the works for him...
Hey "zero"...Nice cardboard back drop.
You ain't nothing special.
Nothing but a run of the mill parts guys.
Ohh, trust me you sure ain't in my head you nut hugger.Hey "zero"...
I love living "rent free" in your tiny little mind...
Guess you like a rougher tool path cut?My version of a SBF. ProFiler. I did the as-cast port for them and the core boxes. This is my 240cc CNC version.
I'm assuming that most gaskets are going to be wider than the divider? Is that detrimental to the flow?with a gasket?!?
Mr Gasket 5824 fits it perfectly.I'm assuming that most gaskets are going to be wider than the divider? Is that detrimental to the flow?
