My bench has been calibrated with sharp edge orifice plates to the American Society of Mechanical Engineers MFC-3M-2004 national standard.
I also reference SAE J228 Airflow Reference Standards
It's the standard used by engineers world wide, ..
To me, it's important to have a "true" CFM number from my bench because of all the
other calculations I use to design heads, .. mass airflow, cfm demand, cfm per Hp airspeed, etc,
So I totally re-calibrated my bench from when I got it, ..
It would be easy for everyone to calibrate to the same standards, .. but most don't worry about it
as long as the bench repeats. So really most of us use a bench as our own little yard stick to measure improvements. The problem is consumers use it to judge
what head is better, and unless all of the benches are calibrated the same and the test methods all the same, they don't really compare.
I do NOT use a pipe for my published exhaust port numbers but I do test with
them VERY often.
On the intake I have radius plates etc that I use that are fairly consistent, .. a few
manifolds that are my test standards, .. and some fabricated "runners" , ..
it all depends on what I'm testing for.
I have a Saenz 600 bench that probably compares mostly to a 1020, .. it's more
conservative then most commercial bench calibrations.
Curtis
