1 - 8 of 8 Posts
I use a band saw today but use to use a sabre saw years ago. Go slow with a scribed line not magic markered or something and I used WD40 to keep the blade clean. RM
T/S 368E
Band saw also, have used jig saw in the past. As mentioned, check teeth often, they get clogged easy.
I use auto trans fluid on the blade... works well... also use it on carbide cutters to keep clean when working with alu..
or plazma cut
mike
I make a wood template.Then Jigsaw close to template on low speed w/ cutting oil.Then clamp the aluminum and wood together and router the aluminum to your template.
This looks more professional than sanded edges IMO.....
Or CNC?
winners circle
i used a sawzall and a my brother air file to make it was straight and smooth.
1 - 8 of 8 Posts
