1 - 20 of 60 Posts
i was given a good clean 150 gal propane tank. still has about 5 gals in it. the propane place will not recert it because of the rust under the data plate (it is pretty bad). i can bleed off the rest of the propane no problem....BUT
how do i cut it.. wanting to build a nice BBQ pit out of it.
i have heard of people filling them with water crossing their fingers and lighting the tourch....lol
any sugestions???
Yellowbullet Overlord
How are you going to put up a post like this while having the signature line that you do?
No have someone ELSE video it ...
cause he's gonna blow the fuck up!!
shoot it 1st from 100 yards away & if it don't blow up your all good. I guess you should empty it 1st if you want. :smt068
Cutting a Propane Tank
First Advise: DON'T
Second: If you just must, at least drain it, evacuate it and fill it with an inert gas.
Third: Take out a sizable life insurance policy and name me as your benificary.
And, as the guy suggested; have someone else videotape it for us, from a distance. Think of it as your legacy.
It's been good knowing you.
cutting torch should work great as long as you keep the little bit of propane that is in it on the bottom of the tank, and be careful not to set the video camera up to close to you while you do it as we would like to get the whole effect of the explosion no I mean whole effect of the process, :smt082
Please post video after you get out of the hospital
Smoke Em if you got Em
empty it out. Remove the nozzle allow the tank to be open to the air for a week, then cut away!
Whats that motivational poster............ Sometimes you have to realize is that your only purpose in life is to be a lesson for others.
Just kidding hahaha, I would only do it if I knew it was EMPTY, flush it with water a bunch then fill it with water (not under pressure) and take a cut off wheel to it.
Even then its not worth the risk.
I see another one of those, Hey guy's Watch this stories in the making. Really though an inert gas would be the only way I would try that, water would not get into all the very small places inside the tank, but then after you puncture it all the gas would be gone, I would Google how to do it.
We did a 200 gallon tank.Take the valve off and fill it with water and let it sit for a few days full of water.When you get ready to cut put the waterhose in it and let it run slow.Then torch away.It will pop a little but once you get the first cut done your good to go.The water takes a few days to get into all the pores in the metal that the propane is trapped in.
We did a 200 gallon tank.Take the valve off and fill it with water and let it sit for a few days full of water.When you get ready to cut put the waterhose in it and let it run slow.Then torch away.It will pop a little but once you get the first cut done you won't feel a thing.The water takes a few days to get into all the pores in the metal that the propane is trapped in.
*** fixed.
Let's define "pop a little".
g
1 - 20 of 60 Posts
