1 - 8 of 8 Posts
can i cut the bracket in half at the axle tube center so i dont have to cut ends off of housing . have ladder bars now on a fab housing w/backbrace,so it would take alot of work to cut it all off ,could i just use the ladder brackets for the 4 link the spacing from center to center seems close . 4 link brackets would set inside of ladder brackets so i could run either set-up unlimited radial doesnt allow 4 link ,but 10.5 does car should fit into both classes , incase your wondering why im asking .thanks
i would not suggest welding four link brackets on your housing if you have housing ends already installed that line up with your 3rd member. i promise you that they wont line up when your done. you NEED to cut your housing ends off, put the brackets on and then put new housing ends back on.
Ditto.....you'd be surprised at how little heat it takes to starting moving the axle tubes around....and you're going to put ALOT of heat in it welding 4 link brackets on. Clamp that SOB down solid and hope for the best.
Banned
You may want to buy another housing and sell your current one. Gonna take a lot of work to put the new brackets on and without a really solid fixture which most of us do not have, things are gonna move.
7.86 @ 8800DA 3365lb 275s
you can cut them and weld them on but you will wish you hadn't when your done. after welding your housing brackets on the axles will probably be in a bind because of housing ends being misaligned.
my opinion,
Justin
x2, housing will distort when welding on it. ends are the last thing that you do as far as welding to your housing
Pic shows how far I offset the tubes in the sheet metal housing I designed and built.
Sensitive content, not recommended for those under 18
Show Content
Came out centered up much better than any housing I have ever done. SOB of a job to get those bushings out though. :eek:
1 - 8 of 8 Posts
