540" BBC Alum. BMP Merlin X, F-1R Procharger, 12-rib [email protected], 11psi, AFR 357 heads, E-85 '86 Camaro
I have the headers built and have the oval tube for the side tail pipes pretty much planned out. Based on the room available for mufflers (about the same on both sides), what would you make the internals look like to get some noise reduction, even if it meant sacrificing some HP? I see factory muffler cutaways focus on sending the exhaust into and out of perforated tubes, sometimes with roughly divided chambers without any packing. I've had Flowmasters on the car and have cut them open to look at the 'delta' design and have seen Spin Tech cutaways as well. So far I'm thinking the shape leans towards 2 chambers with a connecting tube (2nd picture) to get a few sudden velocity/pressure changes to occur, then maybe add some obstacles in each of the chambers or pockets of perforated stainless with stainless packing behind them. All guessing though!
The engine is a BBC 540, Procharger F1-R, 2.25 primaries to 3.5 merge to 4" secondary. (What looks like bullet mufflers in the CAD below are just the flex couplers.)
