Yeah, if you can pull that front cap off and look for some casting marks.Usually a crank that heavily shot peened is cast. I had a Scat cast steel crank that was peened heavy like that. Never saw a 4340 crank that heavy.
Scat and many others put their info on the fron of the fron counterweight. Its hard to see with the front main cap in the way sometimes. Might need to remove it.
I think Scat rates (HP) all their products on their website, but I havent looked. I know Eagle does....if it was a cast steel crank what kind of hp can it hold it is a 331 ford
That ther is a 302 main, 3.250 stroke, 5.400 long rodthe part # on the crank is 302 3250 5400 5140 y0307
