1 - 20 of 21 Posts
does anyone know of somebody that is GOOD. Im looking for someone with their own grinder not a shop that subs it out, then points fingers when the parts aren't right. do you guys have any suggestions?
Cody
Call Christmas automotive, those fat and furious guys, I'm sure they hook you up for like 30k and maybe for an extra 5,000.00 get you in the elevens !
I have personally taking my Vega to Christmas and he does great work.. I think that I gave him like 28000 to install a fuel pump and. Also a plate style nos kit. Fucking car flew after that... ran 8's in the 1/8 according to a stop watch... i did see tommy grinding a crank with a bench mounted drill press, some wd40 and a gouging chisel. He said the crank was from a ford tractor and they were going to run honda bearings in it. Said he learned that trick from nascar. He the cut eyebrows in the on the oil holes that went half way through the crank... said it makes a oil reservoir incase the mains get starved for oil.. I would let him work on my bryant crank if i had the money..
Seriously RO-DY IS IN PLYMOUTH MI... i dont know if crankshaft craftsmen are still on davision..... they did awesome work.. had them offset grind a lot of cranks
Man!!...."That's Funny" Good One.:smt100
R&R or Center Automotive in Akron. Both top notch. Both do EVERYTHING in house.
Ohio Crankshaft?
Dont know distance though.
1 - 20 of 21 Posts
