1 - 8 of 8 Posts
I have turbo motor and I keep blowing out the dip stick. I currently have a 12an line coming off each valve cover to two breather tanks. I was told I shouldnt need a vacuum pump and would like not to have to put one on. What is everybody else doing?
12an lines should be plenty enough you have other issues going on to blow the dipstick out takes some pressure more than a healthy engine should make
No dip stick but do have one #12 in each valve cover going to breather tanks with no problem
i think you have ring issues
2 8ANs here and 700s to the tire
Small tire Pimp
I also have 12 an coming out of the valve covers
But I don't run a dipstick
Discussion Starter · #8 ·
I' ll check compression and see what I have. The motor only has maybe maybe 15 passes. It was built by Nelsons performance but it sat for about 3 or so years before being started. Thanks for the advice.
1 - 8 of 8 Posts
