1 - 3 of 3 Posts
I have noticed that I dont believe I have adequate crankcase evac. I have dual -10 fittings into a single breather. On each valve cover I have a single -10 fitting.
I believe this is the reason why I am pushing a small amound of oil past the valve cover bolt grommets.
On a turbo setup without a vacuum pump currently what is the best way to get a proper evac system.
Discussion Starter #2
Also not entirely sure my catch can setup is all that bad, my main reason for thinking so is that the grommets for the centerbolt valve covers leak a bit but nothing else leaks on the engine.
I almost wonder if the gmpp chevrolet cast alum valve covers are the source and they are powdercoated...
best pic i have to illustrate the setup
i have a setup like you but where your breather is i have a -12 going to the exh throught a evac check valve like they run in headers. seems to work well and from time to time i have some oil residue in the catch can.
1 - 3 of 3 Posts
