I'm installing a crank trigger for the first time and need opinions if I’m going about this correctly? First I set the Engine a 28* btdc, set the distributer rotor pointing at #1 terminal on the cap, then placed the trigger pick up over a magnet on the crank trigger wheel.
I want to start with 28* and possible work my way up from there. I have a MSD 7531 and when I get the base timing figured out I will use the ignition box too remove a few degrees on the launch.
The combo is: sbc, Procharger F-2, blow thru deal.
Thanks,
Thanks,
