1 - 5 of 5 Posts
Alright I got my pan to fit with the windage tray by trimming some of the oil pan baffles. Now, is a crank scraper a good investment? Also Mildon makes a plate that goes under the oil pump to help hold the oil in the sump during hard acceleration. Good investment or a waste of money. BBC.
F.T.W. KILL EM ALL
You ask if a Scraper is a good investment...The short answer in my opinion w/o getting into alot of the "Tech" about one would be........ YES.
Just my $.02
Anything you can do to help keep the oil in the pan and not spinning around with the crank will be a good idea and a scraper helps do that.
Senior phuckstick
Good oil control helps an engine live. Consider a good pan with windage control. Some use screens, others use louvers.
1 - 5 of 5 Posts
