1 - 9 of 9 Posts
RED ROCKET
fixin to swap my 85 camaro to and 8-71 and cruise on the weekends a little with it on pump gas..not a daily driver.LOL
will be a 598 w/8.8 compression ,360cc alum heads,mild solid roller,quickfuel 4150 carbs,turbo 400 with a 3500 stall.
not much room at the front..will a crank hub be ok to drive around with?plan to have 1 vbelt pulley for my alternator.
RED ROCKET
Discussion Starter · #4 ·
thanks guys...it will get a hub.
Yes, no problem. Pulled my motor down after 4000 miles and the bearings were still like new.
just make sure you keep an eye on the timing chain because it can take a toll on it without a balancer, my suggestion is run a gear drive if your going to not run a balancer, other than that i have had no problems running just a hub
I had almost 10000 miles on my 434, bds 8/71 stage II, crank hub, 719 at the back tires on 93. I had just a timing chain no gear drive. I beat the phuckin snot out of it every time I drove it. Then sold it and as far as I know still no problems.
pretty much same here but have seen some extra wear on the chain after a while,, just sayin
I not saying your wrong, I am just saying It lasted over 10000 miles I had no prob. I think it would be best to run a belt drive vers a gear drive??????
1 - 9 of 9 Posts
