1 - 7 of 7 Posts
Does anyone know where to get a crank bolt that will work with a crank trigger and a v-belt pulley?
What kind of crank is it? Callies Magnum cranks require a special stud because the threads are much deeper in the snout.
Hey guys, thanks for the replies. Apparently I have been doing it wrong all these years. Found out that the bolt goes into the crank before you put on your crank trigger and pully because the damper is recessed. When I pulled the crank trigger and pully off, I noticed the ATI damper I'm using is not recessed. So I just took the centering ring out of the trigger wheel, and it worked that way. Hope it's right! lol
1 - 7 of 7 Posts
