So do you yet make a rocker that doesn't need the corners ground off to fit under stock BBC valve covers?I think Crane and a few other companies all buy a standard bearing from a common supplier. Maybe you can locate the supplier, or see if Crane or another company using the same bearing can sell you replacements.
I'd offer to get you some but we make our own bearing assemblies and they wouldn't interchange.
Have you looked at our Diamond series rockers? They're tapered on the corners for weight reduction and extra clearance. Go to our website (link in my sig.), click on Products Catalog, Chevrolet Stud Mount, and scroll down to BBC Diamond rockers. That might help with you with clearance issues. Here is a pic:So do you yet make a rocker that doesn't need the corners ground off to fit under stock BBC valve covers?
WJ check it out,, rockers to match the color of your truck,, now thats styleHave you looked at our Diamond series rockers? They're tapered on the corners for weight reduction and extra clearance. Go to our website (link in my sig.), click on Products Catalog, Chevrolet Stud Mount, and scroll down to BBC Diamond rockers. That might help with you with clearance issues. Here is a pic:
LoL, yeah now I owe the anodizing guy a favor.WJ check it out,, rockers to match the color of your truck,, now thats style![]()
Thanks. Found them and got a full set for $120. The Timken/Torrington looks to be a MUCH better bearing than what was installed from Crane. I just couldn't see not fixing these since the bodies and axles were pristine.I've purchased bearing from ALLIED Bearings for rockers.Torrington b-96 $4 a piece.
