1 - 16 of 16 Posts
anyone know where i can check a grind of a camshaft.i have all the numbers.was crane bought out or closed down?
118421 part number grind number r-268/4467-25-6.96 lift @cam 4467 4167 1.5 rocker 670 620....cam tming tappet @.0202 opens i 45btdc ex 83 bbdc closes i 73 abdc ex 51 atdc adv dur 298 314 rpm 4400 to 8200 float at 8800 with springs 99885-16 closed 215 lbs @1.950 open 586 @1.330 can timing @050 i 31 btdc ex 67 bbdc closes i 57abdc ex 29 atdc max lift i 103 ex 109 dur 268 276 cam has 960 base circle valve setting i .012 ex .022
THANKS!!!!do you think this will work well in a 434...2100lb camaro?fax 803-324-0006..thanks again
Discussion Starter #8
i got it...don't see the centerline do you know what it is or how to figure it out?
Discussion Starter #14
just noticed you have a speed shop.what you got that you would recommend?and how much?
WHAT YOU HAVE IS FINE . I WANT TO SELL SOMETHING BUT IF YOU HAVE THAT CAM AND IT IS IN GOOD SHAPE ALL I WOULD DO IS TAKE YOUR MONEY PUT GOOD SPRINGS ON THE HEADS AND LET IT EAT
Discussion Starter #16
ok...gonna put motor in my buddies pinto so he can race carolina dragway this weekend.i gotta go to the beach.
1 - 16 of 16 Posts
