1 - 5 of 5 Posts
Car did a wheelstand came down real hard my fault wasnt expecting it.Motor is 6 liter iron block.The crack is hairline crack right over the oil filter next to the rear cover.Oil sweats out of it.Can i use the gray rtv on it and get by for the season?I will drill a small hole at the end of the crack so it dosn't spread.
If you pull the motor, you can have the crack pinned and braze it shut with silicon bronze rod.
i do plan on doing a perment fix or if the machine shop says get a new block.But am i pissing into the wind trying to silcone it to get by?
1 - 5 of 5 Posts
