Just wondering if one of our manufacturers here can answer me a couple of questions:
Do the coyote and Conventional modular engines have the same tooth count on the crank trigger wheels? I doubt they are the same wheel? If not what is the tooth count for each?
I know ford racing makes a replacement wheel for the coyote...is this the same tooth count or did they alter that for extended RPMs ?
Considering a coyote with a mechanical fuel injection setup. Thinking about a crankshaft belt drive distributor vs. The MSD mod motor controller for COP's but if the tooth count on the trigger wheel is different I don't know if that will work.
P.s. I'm okay with fab work. Have access to nearly any type of equipment or expertise to get the job done.
