I have a coyote swap in a 97 mustang GT . DTC code P0012 came up on an OBDII scan . P0012 is the Intake cam bank 1 over retarded .Went to a Ford Roush dealer , they did an IDS scan and confirmed the intake cam bank 1 was showing no activity , other than a tiny bit of mechanical movement .
I checked solenoid circuit, it's good. Replaced the phaser solenoid thinking that was the problem, still pulled P0012. Next fix is to replace the intake cam phaser or plugged screen . Replaced with new intake phaser, and new screens . Put engine back together, still P0012 code. Cleared codes with battery disabled overnite each time . Code is gone until I go WOT, then code pops up
Checked bank 1 cam oil gallery , good volume of oil in a fitted hose and good pressure . filled a quart can in a matter of seconds . Then i blew out the oil gallery with compressed air, could hear the oil blowing out of the cams and air inside the head. There doesn't seem to be a blockage of oil in the gallery and the holes in the cam ends where the screens live were clean , the screens are clean , no debris anywhere .
I can drive in traffic and no code , Go WOT, code pops up, clear code , same code pops up WOT. Only revving to 6800 ,not going into rev limiter.
Engine is a 2012 crate engine new from FFRP in 2012, currently with 2500 miles on it . Driveability can be better at times and WOT power is not all there for a coyote . Still using FFRP tune and PCM has been reflashed with current tune using 94 octane. Hoping some modular guys with phaser savvy can help me . I'm against the wall at the moment , don't know what to do next . Same inquiry has gone to Ford Racing , they said they would run it by an engineer . Nothing so far
Looking for a little help ....... anyone ?
