1 - 3 of 3 Posts
I have a short deck bowtie block and I want to put in a 4.250 stroke crank with carrillo I beam rods ...how much if any will I have to clearance the block ?? I am also looking for a couple of scrap 4.500 Big Block piston to locate the rod correctly in the bore while I check clearance and grind the block as I will be going out to 4.530 , i would like to do all the grinding before boring and cam bearing etc..any advice would be appreciated .
Thanks Dave
1 - 3 of 3 Posts
