Fox body hatch, weighs around 3100-3200lbs. Will make around 900-1000rw through a stick but I wanna switch to an auto. Solid roller/turbo car that will be driven on the street on a regular basis. Tires are 275/60/15 and right now its got a 3.55 rear gear.
Would really like overdrive to make cruising on the hwy semi nice, I live 20-30 miles away from most of the good meets so I log some hwy time.
-TH400
-Glide
-4R70, OD ford trans
-4L80 if there is a nice setup that will work in a fox body?
If the TH400 or Glide is the choice, what gearing would work? I'd plan on adding a Gear Vendors unit to it
Thanks guys
-TH400
-Glide
Thanks guys
