I have a 38mm Turbosmart ultragate wastegate that i have left over from my 70mm turbo build. Now i'm stepping up to an s480 and wondering if i have real good placement on the wastegate if i would be able to get away with using the 38mm gate on the 80mm s480? The lowest boost i'll be running is around 8-10psi pretty much all the time so not worried if i can't control boost down any lower than that.
What do you guys think?
