1 - 7 of 7 Posts
That guy...
I'm thinking about converting my generator to propane because I don't want to install a gas tank in my trailer. I can use propane for the gennie and T into it for a gas grill...
I have an Onan GenSet 6.5
  • Who's done it? Why? How?
  • How much did it cost?
  • Does it cost more in propane to run? Less? Same?
  • Any noticeable difference in the generator?
When converting a gas generator to propane you will loose about 20 to 30% power on the engine and KW output. Add that with losses in a hot environment and your down maybe to 50%. So now the gen set wont provide enough power for your needs. Just something you may need to think about.
only thing i noticed on mine it is a little harder to start in cold weather. but then mine is an old military unit with low compression. 30 kw 6 cyl.
I converted an Onan 4KW from an old motor home to propane. Got the parts from propanecarbs.com. Simple conversion and worked perfectly. Ran everything I needed to run. No more stuck floats, either!
Most RV manufacturers have gotten away from even offering propane gen sets in motorhomes due to the disadvantages.
That guy...
Discussion Starter #7
Can you explain what those disadvantages are?
1 - 7 of 7 Posts
