1 - 6 of 6 Posts
the past two races my car has slowed down a little over a tenth ..most notably in the 60 ft.
60 ft times were normally around 1.48..they are now around 1.53
..it also seems impossible to cut a light..i am an experienced racer with well over 1000 passes. i can tell the difference between a bad light and a good light and right now they are ridiculous...they consistently go from .030 to -.030
car seems to have lost most of the et from the 60 ft to the 1/8 mile.
also , mph has stayed the same from when it was running good..128 mph.
lastly , its a 5000 stall converter..when i did the " stall test" it came up to 6200...all help is appreciated . thanks
A sprag failure will lower the stall not increase it. I would have the trans/converter checked but I can't pinpoint a problem from the description exactly.
Hutch
thanks guys...tranny is brand new converter isnt , i have a spragless in the garage with only a couple passes i might throw in . probably going to run the car one more time the way it is .( i had alot of people telling me there car was doing the same theing= horrible track conditions ) but something is also telling me that it probably wasnt the track
1 - 6 of 6 Posts
