have a PTC converter i had pad spacers welded on at PTC..they sent me 6 bolts and 3 nuts..my converter has 3 pads that is thearded and 3 that is not..on the 3 pads that i use bolts and nuts on..do i need lock washers between pad and nut?or just use red loc-tight?or should i get self locking nuts?also should i be using flat washers between bolt head and flex plate? also on the 3 pads that is theaded what should i do there?
