I have a HP Computer. Today when I got on The print on the screen changed to very small...Can't read it without getting a headache...Any Idea how to make the print bigger?
It can be one of two things.
Re-adjust your screen resolution to the recomended setting that your monitor is set for,
Or
Hold the control key down and at the same time use the roller buton on you mouse to adjust it. If you dont have a roller mechanism on your mouse, you might see down at the bottom right hand side of the screen (above the clock) a percentage factor (aka as zoom level) click on that and adjust to 100%.
