I am currently piecing together a spare 598 short block. I need a 6.800 length rod. Has anyone used these rods. http://www.callies.com/compstar/connecting-rods/i-beams/
It will be a Merlin block 4.60 bore with JE 1.12CH pistons. Lunati 4 1/2" stroke crank. It will probably end up with a set of dart 355 heads. Looking to make around 900 horse then an occasional .024 to .036 nitrous jet. Probably around 1200 horse total. But again will only be used occasionally and will be a back up engine.
The engine may see around 7500 RPM max but will be set up for nitrous(gear and converter) and possible limited street duty(10-15 miles a week) Probably close to 7000 or less normal duty.
I was going to use either the Eagle, Scat or H-beat Compstar rod but i think these HD I-beams may be better. Will these work with my application or will something else be better for around the same price of $850?
