1 - 7 of 7 Posts
I am looking for back to back tests:
If I raise compression ratio from 9,0 to 10,0
how will be the turbo spool?
Fuel is E85
twin 68s on 5.0L V8
Compression ratio will always help with spool, but timing controll is better.
See I tend to think spool will not be effected a whole heck of a lot. But, E85 likes higher compression and your off boost will be better. Power will also be better. But I really don't think spool will be a lot different.
U have a better transient response with higher commoression. Normally with higher compression Turbo car will make more power per psi but the tune has to be spot on. Also the huger compression u go the more your limited on pump gas.
1 - 7 of 7 Posts
