x2i`d go with the thicker gasket and not worry about that half a point of compression, its not gonna be worth hardly any power on the hose
X2I would go thicker.More of a tuning window and I don't think you will loose much.
Dont mean to highjack but this concerns me because I am zero deck and need to run a thick gasket plus I'm running a merlin II block that dont have the extra lifter valley bolts. Any truth to this?thinner gaskets conform better to surface and seal better
Steve Monte Your thoughts ?406 sbc RFD 18 degree heads cam 269 281 @.050 450 worth of nitrous pistons .020 in the hole . So here is the question .040 head gasket or .053 ?
.040 = .060 quench 13.02 compression
.053 = .073 quench 12.53 compression
.053" w/ steel rods and if aluminum rods, prob an .060"Steve Monte Your thoughts ?
Steelsteel or aluminum rods?
.063 cometics on mine.Dont mean to highjack but this concerns me because I am zero deck and need to run a thick gasket plus I'm running a merlin II block that dont have the extra lifter valley bolts. Any truth to this?
I know I have read Monte say he prefers .040 in the hole and a .040 gasket so I need to go with at least a .073 cometic.
not sure about that thick but .051 seems very common.i would think it would be good as long as everything is flat.Dont mean to highjack but this concerns me because I am zero deck and need to run a thick gasket plus I'm running a merlin II block that dont have the extra lifter valley bolts. Any truth to this?
