1 - 4 of 4 Posts
Is there a way to determine your compression ratio by doing a compression test? Just did one on the truck and all the cylinders were right around 130psi... just wanting to confirm what the ratio would be.
440, 0.060" over...
don't know the answer to that question, but that is a bad ass truck you should check out the caging a truck fourm in the chasis section, and be sure to include lots of pics....
1 - 4 of 4 Posts
