1 - 9 of 9 Posts
My trailer is setup with a storage cabinet in the front corner with a pair tool boxes mounted next to it. In the cabinet I have my pancake compressor along with a few other items. Instead of having to connect a line to the compressor and run it out one of the doors, I was thinking about putting in some piping underneath the trailer. And since in my area racing is almost at a standstill, looks like a good time to do it. I have used 1/2" Schedule 40 in my garages for years (30+) and never had any trouble with it. Garages have never been cooled or heated so I don't think temperature is a big factor. The compressor has two quick connect outlets on it so I figured I would use a short connecting hose to the piping, drop down under the floor and run to the rear of the trailer. I would bring it up in the rear corner and mount another quick connect fitting there. This way the only thing exposed would be the piping run. Anyone done the same on their trailer?
T/S 368E
Exactly, I took a damaged air line and I'm planning to use one of these.
I was planning to use a weather proof outlet box, but worried it would be too small??
I didn't like the look of just leaving the outlet showing??
Mine is that way. I am in Florida so no freezing weather here. Schedule 80 is even tougher
Why not just run an air hose under it ?
I think over time a hose would eventually deteriorate and fail. Plus at least on my trailer I think it would be harder to install. Keeping it from drooping would mean fastening it probably to every c-channel under the trailer. I am thinking with pipe it might only be every 3 or so that I would have to clamp it in place.
Tractor trailers use nylon line with compression style fittings, fast fun and easy. I wouldn't hesitate to use PEX, I've used it in my shop air line as an experiment and it works great. PVC is good for waste lines, I'll never use it again for anything with pressure.
We bought a tank to let the pancake compressor fill then set it up to mount under the trailer. It was going to provide a lot larger volume of air and be routed out the side. The guy that actually owned that trailer lost it in the divorce before we finished it. With all of the battery powered impacts and tools I doubt there is the need for that volume of air any longer.
I'd be concerned with PEX rubbing on something.Maybe mounting it in insulated clamps would be enough. Is it susceptible to vibration problems? Maybe use semi air brake lines like this that you can buy by the roll. These guys have a lot of stuff for that.
We mounted a 50' hose reel, and a 50' triple tap 12ga extension cord reel just inside the front side compartment door on the goose neck. No more rolling up the air hose or extension cord anymore. Just give them a tug and they roll themselves up. Can't believe we didn't do it a long time ago. Works perfect. Best part is that its inside, so you don't have to worry about it getting damaged or corroded at all. Remember, if its under the trailer, it can get damaged pretty easy. Especially pvc pipe.
EFI/N2O JUNKIE
I have two 50 foot reels in my Gooseneck, one up front by the landing gear so I can put air in the truck tires and air bags if I need to, and one in the rear for the race car. My 30TAG has one reel in the back. My Gooseneck is plumbed with normal air hose zip tied all the way back so it doesn't sag. The TAG was plumbed in copper. No problems with either one.
1 - 9 of 9 Posts
