1 - 6 of 6 Posts
Is anyone using slide a links on a leaf car? Im setting my car up for the first time with these. I was curious on the proper sarting setting.
We have them on a S-10 and we started with them both slightly touching the pad and then gave them one full turn on the pass side and only half a turn on the drivers side.that should get you a starting point.
Follow the directions that come with them, or as stated above, it will get you in the ballpark, all cars are different.
Thanks. These were on the car I bought and it didnt work for shit. The front end was way tight. Ive got it freed up. So Ill make some base line passes saturday.
1 - 6 of 6 Posts
