I finally got around to pulling out the dyno sheet's from 2007 to compare un-corrected numbers:
2007 DTS dyno : uncorrected
Baro Pressure: 29.2
Humidity: 41%
Air temp: 84*
6,000 706 lbs ft, 804 hp
6,200 699 lbs ft, 825 hp
7,000 643 lbs ft, 857 hp ( corrected 935 )
2011 Super Flow 902 dyno: uncorrected
Baro Pressure: 29.02
Humidity: 45%
Air Temp: 91*
Density Alt: 3,400
un-corrected:
6,000 691 lbs ft, 790 hp
6,200 691 lbs ft, 816 hp
7,000 632 lbs ft , 845 hp ( corrected 944)
Raw data power numbers are with-in 1.1% at 6,200 and 1.5% at 7,000.
G
Baro Pressure: 29.2
Humidity: 41%
Air temp: 84*
Humidity: 45%
Air Temp: 91*
Density Alt: 3,400
un-corrected:
G
