1 - 4 of 4 Posts
Whats up, i gotta Comp roller that is going back in an engine,I did'nt build it originally but its all me this time around ,I can't find the numbers in my Comp catalog ,HELP, here are the numbers that are on it,312665,270492,07121,and a barely legible 35-272or222 maybe, can't read the 35 #s.?????????:confused:
You sure it is a Comp 100%? If so, I would call them. They usually grind the serial number into it along with the grind number unless this is a real old grind. They would know better. Or you can just degree it in..
I'm gonna call Comp today for the specs, thanks
1 - 4 of 4 Posts
