1 - 3 of 3 Posts
I’d like any feedback also. I just bought a set, accidentally without shims. Wondering if I could turn up and grind the shims as I need.
Work as intended. I have ran into clearance issues on one set of heead castings, the thicker lower portion just BARELY contacting. I want to say it was an early TFS casting, on a hyd lifter. Solid lifter would not have same clearance issue as the lifters are @.75" shorter to the pushrod cup
1 - 3 of 3 Posts
