1 - 11 of 11 Posts
This is my plan for my nitrous set up:
Cometic nitrous controller for the fogger
Nos dig timer for the plate as a second stage
My ignition will be a digital 7
Do I need extra solenoids to use for the nitrous controller so the can pulsate my existing solenoids???
My second stage will be a eddy plate with a 125 shot max...
My first stage will be a NOS pro race fogger with 350hp max...
Am I getting to complicated with too many gadgets lol..
I only run the fogger with a digital 7 before never used a progressive or two stages...
Who is running this kind of set up? Is there something to look for?
Why not run the fogger at say 250hp off the transbrake and then bring in 200-250hp with the plate?That way you wouldn't have to mess with a progressive on the first stage.This is what I'm in the process of setting up now.
The only reason I bought this controller because I can use it as a data logger since it has one build in it... I will try using the dig 7 first for traction the progressive is my last resort..!
I don't like using anything over 125-150 in a plate system especially as a second stage...
Fuel and nitrous distribution is nowhere near as good as the fogger... At least I prefer the fogger..!
Chupa Cabra
Wouldn't you want to use the plate first and let the fogger clean up the tune down track?
Discussion Starter #7
With the NC-2 controller, you don't need the digiset. It will progress both stages. And I dont run the redundant "safety" solenoid in front of the progressed one.
Thanks, I was reading the instructions on the controller and I realize I rushed when I ordered the dig set... Oh well I can always return it lol...
I agree.Using a progressive kinda defeats the purpose of running two stages.
The nitrous guy
I disagree...........nitrous is nitrous. Pounds per hour flowed, is pounds per hour flowed. Does not matter if it is one kit, two, or three. Getting a small tired car down the track is all about power management. If you think it will always be easier to manage one monster kit, than two smaller ones, even with a progressive.........about the only thing I can say, is you are wrong.
Single big kits are all the rage right now, because X275 is so popular, but I talk to people on a daily basis, who are struggling, trying to manage a monster single kit, a low percentages, on a junk track. Why limit yourself, if the rules dont make you.
Monte
1 - 11 of 11 Posts
