Or hide behind a screen name because your a scared bitch....Or maybe you should put a chain saw finish in comb chamber like v fucktor does because that fixes everything!
Who taught you that burr finish garbage? Michael j fox? Does your cutter fly out of your grinder allot?Or hide behind a screen name because your a scared bitch....
Your not that special..... But you are 100% a dick head.
You must be pretty sharp ,2250 lb car running 4.57 1/8 mile with an N/A 407 cu/in is kind of impressive. Not as quick as Australian Pro Stock but pretty damn good.If flow bench number is your only concern ,why not blow whole chamber out to head gasket edge and make sure it's lower than the seat ? Its stuff like this that send guys in wrong direction.Way more to be learned on proper mixture motion in dynamic state with fuel and cyl pressure. Once a guy learns a flow bench is better in the corner collecting dust and studies what a running engine has to show them, by far off will their learning curve develope.
I want to thank you for posting your videos and information, I do not respond to the negative posts if they don't add something constructive in the post, that's just me. Keep on keeping on with the Ford stuff, lol, it drives some of those guys nuts, lol.
If the resin is so impregnated that it's almost impossible to get out no matter how much you clean (which I completely disagree with)...then it shouldn't be a problem. Just sayin...I prefer burr finish because the resin that gets impregnated into the ports from the cartridge rolls is almost impossible to get out. No matter how much you clean them they are still filthy. Cant be good for rings and bores.
I see you are successful in racing, and have good knowledge to add. However, even if you DO have something valid to say, nobody is going to want to listen if you come off like an asshole. Try speaking with a woman using that tone, and see how far you get. lolWho taught you that burr finish garbage? Michael j fox? Does your cutter fly out of your grinder allot?
Take a clean rag and acetone on you next sanded manifold and tell he how long it takes to get it clean. Where black shit quits rolling out it.If the resin is so impregnated that it's almost impossible to get out no matter how much you clean (which I completely disagree with)...then it shouldn't be a problem. Just sayin...
Burr finish is one thing. I agree; in areas where there is wet fuel, especially floors, it can be beneficial. Just arbitrarily burr finishing an entire intake is not. Smoke and mirrors IMO.
First you say impossible to get out no matter how much you clean, now you're saying you can wipe it out with acetone. Make up your mind. My point was, if you can't get it out by cleaning, it's not coming out. Besides, if you're getting resin impregnated in your aluminum, you're burning the roll. I don't do that. I've probably ported a hundred intakes or maybe more so this ain't my first rodeo. It's what I do for a living and I usually flap-finish my intakes after cartridge roll anyway. If the intake is right, the finish isn't going to make a hill of beans other than wet fuel areas. Save that nonsense for those who don't know any better.Take a clean rag and acetone on you next sanded manifold and tell he how long it takes to get it clean. Where black shit quits rolling out it.
Its as simple as doing your own AB dyno test. Its not that hard to find a customer that will let you do it. Put it on burr finish first, then sand it, what you would do anyway, and when you see the time spent sanding, cleaning, and count the cartridge rolls used, ask yourself was it worth it to gain nothing or possibly lose power.
