1 - 5 of 5 Posts
i have been fighting steering issues. think i got it worked out but not sure. but checkin out the car i found that the rear bumper did not look level. measured and found the rear shock center to center mounting was smaller on driver side that pass side. were set up even at the start but that was a few years ago. these are coil overs by the way. qa 1 single adjust with 12-130 springs. spring installed heights are off now by almost an inch. could i have a collapsed spring or something else. how do i tell. thanks
measuring compressed length will full weight minus me in car and driver side is almost an inch lower than pass side. with another 200 pounds it will be even lower.
1 - 5 of 5 Posts
