1 - 7 of 7 Posts
looking for a 1440 50mm belt. looking for a kevlar belt does anyone have any part #'s. i got some gates cog belts but i think they are for convayer belts only lasted 20 dyno runs before they ripped the teeth off. is their an automotive belt and an industrial belt? just need some that will last.
try a gates carbon gt ,, strongest belt they make and it can run an idler on either side, as far as automotive or conveyer they are all the same
Discussion Starter · #4 ·
what length belt do you think i would need for a 88t crank and 36t upper on a 8.2 sbf deck 1440 is way to small and a 1580 is way to long
you are running into the smae problem that i have... lol i have a 77 crank and a 38 blower on a bbc and the belt that it calls for is a 1540 1550 witch gates does not make gates belts go from 1440 to 1584 dont ask me why !!!!! their are 2 thread about this problem
http://www.yellowbullet.com/forum/showthread.php?t=219435
and
http://www.yellowbullet.com/forum/showthread.php?t=243131
good luck
1 - 7 of 7 Posts
