Are there any Trans issues to be had with clicking an engine off just past the finish line, and coasting to a stop, to be able to check a spark plug? I have a Turbo 400 in my car.
Doing that with a TH400........IS JUST PLAIN STUPID!
I have had to fix the damage caused by the shrapnel EXPLODING
the bellhousing and going through the dash, windshield and passenger door and window.
On my friends 1955 Chevy.
HE was EXTREMELY LUCKY not to be hurt!
Somethng about the internal "something" going from
ZERO to 7,000 rpm..........kablooeey........
DON'T DO IT!
Do a search for it, or Google it.
"Another reason for the use of the billet drum is preventing a drum explosion in the event that it would go into an overspeed condition when shifting from high gear into neutral under load, where drum speed can nearly double. Cast iron, in this situation, would simply explode at the nearly 14,000 RPM it might see. The hard anodizing of the direct drum increases the surface hardness, giving it more longevity. Aluminum is a naturally “soft” material, and the hard anodizing reduces wear that aluminum is prone to inside the lugs where the direct steels are located inside the drum."
I lifted this directly from HUGHES RACING TRANSISSIONN
Your Pal, Gary
